humvmech
- 0
- 0
- salt lake city
So i know lots of people have posted about glow plug/preheat problems on this website because i have been reading as many as i can. I have been fixing a bunch of hummers that my boss has purchased for re-sale (20 to be exact) and this one has been putting up a real fight so i will give you the full story. at first inspection I found that the wait light would only flash for a split second and then turn off. The engine would start but only with a quick squirt of starting fluid. eventually i found that the head gaskets were bad so we pulled the engine and found that the cylinder walls were beyond normal machining so we had to install oversized pistons and did a complete rebuild on the entire engine. new bearings, caps, rods, pushrods, new heads, new valves, pretty much everything that can be replaced was replaced. So with the new heads and everything else i replaced the glowplugs as well just to be safe. after finishing the install it still had the quick flash on the wait light and would start after some extended crank time. This was mid august in utah so it was 90-100 degrees most of the time so the crank time was not that bad but still longer than normal. After more investigating and opening up the originally installed Nartron box that everyone knows is a usual culprit, i found that some of the capacitors and contacts inside were pretty well fried. So assuming that the box was my problem i ordered a new one (a new KDS module with the tempeture sensor that installs in the crossover coolant pipe) after disconnecting the battery (before install) and verifiying that all the glowplugs were connected and all the grounds were attached properly, i attempted to start the engine and once again saw the quick flash on the wait light. still a long, if not longer crank time before starting occurs. I have gone through everything a few more times checking all connections and possible wiring issues i cannot find any causes to my problem. My biggest question is: are the Nartron and KDS control boxes interchangeable? The Box that i received did come with the yellow banded temp sensor/controller. any help will be greatly appreciated.
