panzerjunky
- 0
- 0
- san diego ca
Hello
Thanks for all the help from you guys on the Hydraulic head repair I had going But now She will not start.
Here is a little history
Had a leak in the IP bad gaskets fixed that while I was at it I replaced all of the plastic fuel lines from the small 1/8 inch 1/4 between injectors and such up to the 3/8 from and to the filters. As I had the drivers side fender off figgured this was the time to do this.
got it all done tried to start after a few cranks she started but ran super rough very low RPM ( she ran beautifully before the IP Repair) then the rpm started to max ilke it was a runaway I pulled the engine stop and she shut down.
Tried to restart no luck nothing. Bled a little air from the filters minimal still nothing .
Any Ideas?
Thanks Jerry
Any Ideas?
Thanks Jerry
