CBR Metalworks
Banned
- 526
- 6
- 0
- Winston-Salem, NC
A friend of mine and I went and hooked to the sled at a local pull just to see what the trucks would do. They loaded the sled heavy (as heavy as they had it that night), they told me it was about 45k lbs (including the weight of the sled). Obviously that is 45k DRAGGING which compounds that weight greatly.
The 800 series bogged down pretty quick, 2nd gear low range.
I pulled the 920 in 3rd gear, it didn't lose power and was still pulling even after the weight hit the front of the sled AND the sled operator picked the back of the sled up, but it started hopping so I let out. I'll definitely try it again, but next time I will probably run in 5th gear to get a little more momentum.
https://youtu.be/97P9EKONP1c
https://youtu.be/Esm8eLu4ZAs
https://youtu.be/YMQTSWLWSRw
