Pinsandpitons
- 54
- 28
- Central Washington
On my FLU419 the oil pressure takes about 11 seconds to register on the gage. This is consistent every time the engine is started after sitting overnight. It occurs to me now that I haven't confirmed how long it lags after a few minutes off with the engine warm, but not long. As you might imagine I'm reluctant to start the engine and find out. I can't confirm with the documents I have where (or whether there is) a check valve or anti backflow system in the oil filter filtration but I suspect there is and that's what needs attention. Any input from those more familiar with the OM352?
Edit:
The pressure rises quickly ( 0.5 sec ) after the lag and is strong in the 70psi range at idle.
Edit:
