softboyled
- 0
- 1
- Portland, OR
Hi,
I searched a bit, but couldn't find anything on this...
I decided this evening to finally check and change the glow plugs in my 1010. I had some cold weather starting problems this past winter that I never really resolved, so I've had the plugs in had for a while. I got the wellman ones from the recommended ebay guy (marked 6a843g070). I tested all 8 and found resistance of ~3 ohms at the lowest (3), ~12 ohms (4) and one open. I changed each one seperately, making sure that the wires went back to where they belonged. I checked the resistance of the installed plugs and found six of them to be ~3 ohms, one to be 0.1 ohms (!) and the last (open) one was frozen, so I didn't change it. I left the hood open (thank goodness), turned the key to on, and waited for the loght to go out. I noticed right away that the voltage read a bit lower than normal (low end of the yellow). Then I noticed the smoke and turned it off. I rechecked the wires for frayed insulation (none) and general connectedness. It all looked good.
The only other thing I did was put a drop of oil on the plug threads before installing them.
Any ideas???
Thanks,
Greg
Any ideas???
Thanks,
Greg
