So - what do you think
6x6guy
21
McHenry, Il.
I have checked the past threads on this but couldn't find anything that would meet
the functional and practical application that I was looking for- so I decided to take a stab at it - and this is what I came up with.
WillWagner
2,611
Monrovia, Ca.
Very clean and out of the way! Unless you get folding steps, then the drivers side might have a clearance issue. By the looks of that beast, you might want to look into them!
73m819
319
gainesville, ga.
A MUD CATCHER which it WILL BE by looking at the front tires, off road use, it will find every low bush, a bark scraper when trees are pushed over, the PINS will up and leave once the retainers are knocked out, I see the TB and/or mount getting BENT from hitting something,
On top of everything else, the front end of the deuce has about all the weight it can carry WITHOUT adding more
6x6guy
21
McHenry, Il.
As I was looking for some function- it brought me back a couple of years ago when I was really involved with off roading - the design of the rack was placed in a area
high enough that it wouldn't be in the way of clearing a path- and pushing down any
bushes in the way- it still is much higher that the front and rear axles that would be a real concern as far as clearance.
319
Lieutenant
58
Michigan
I like that. Good clean install. Might do that myself. In regards to off-road use, it will serve as an extra guard for those pesky trees as you drive over them. Are those padlocks GI? If not, I have them, cadmium plated, perfect for outside use like that. http://www.steelsoldiers.com/tools-misc-sale/77900-padlock-sets-sale.html
On another note, can you post photos of your A frame set up?
Edit: Oops! A little slow today!
73m819
319
gainesville, ga.
Now that we have pics of the a-frame, what about the boom sticking out over the side at the rear of the bed, some info please
swbradley1
Modertator
1,689
Dayton, OH
I like the mount and it is a good idea. I don't like the location. I have seen some spots and been riding with people who would tear that off or hang the truck on it. Like Ron said, you are taking a front heavy truck without a winch, putting a winch on it and then adding a medium tow bar to it.
But I do like the design, maybe under the bed somewhere.
73m819
319
gainesville, ga.
ON your a-frame, I would make a spacer to go between the top of the front spring and the spring stop so when the a-frame is loaded, the load is transfered to the axle and stays off the springs, just a thought
