soft pedal
beastm35
plainfield ct
Hello, had to add brake fluid I can build the pedal up to firm but it will lose it in seconds. The truck did not run in years,I dont see any fluid leaking at the wheels so could it be the airpak?I bleed the airpak and brake fluid comes out so not sure..also there is a air line going to the blow by tube with air coming out why..thanks any help..
porkysplace
1,492
mid- michigan
Did you bleed the whole system or just the air-pak ?
The line going to the blow-by tube is a vent for the master cylinder.
porkysplace
1,492
mid- michigan
