Soft top care
kennys@wi.rr.com
23
Waukesha, WI
How durable are the soft tops to the elements? Is there anything special I can do to extend the life of a soft top? I am closer and closer to buying a truck on GL and I want to make sure I do all my home work so forgive me if I ask alot of questions.
As always thank you.
combat32
106
Booneville AR.
It is vinyl as far as I know, any vinyl cleaning and preservative type product, same as you might use on your car.It's worst enemy is sunlight which will make it stiff and brittle over time.
kennys@wi.rr.com
23
Waukesha, WI
Thank you for that info. Now my next question is, how bad isit if the truck is missing a head light? Hardware appears to be there just no light. Are these normal lights, special lights?
Thank you
markmontana
Mesquite, NV/Layton, UT
Thank you
24v headlights are easy to get from any of the usual vendors- $25 to $35. I just picked up a deuce that is missing both lights.
You will need the trim rings- mine were still on the truck.
