DanR7985
- 0
- 0
- Greenview, IL
Hi there. This is my first post. I looked around for the answer for this question, but nothing real definitive was said to me. This coming week I am going to be buying an M1009. It is bone stock. I want to put a 4 inch suspension lift on it, with a transfer case drop, and run 35 in tires. My main question is regarding after that. I have a matching set GM Dana 44 front and Dana 60 rear from a late 70's truck with 4.56 gears. Will the axles bolt right in, and match up with the drive shafts, brake lines, spring perches, while using the same lift kit, or will I have to do a lot of mods to get it to work. This will mainly be on road driving, but with a little offroad now and again. Would I be better off just keeping the stock 10 bolt since I wouldn't have to go through the trouble, or would the swap be easy as cake. If there is any real mods I couldn't do it, but if it is just bolt in I could manage. Thanks for the answer.
