Soot from exhaust, turbo
DIESEL PULLER
VIRGINIA,MINNESOTA
I have a M35A3 I think there is an exhaust leak before the muffler on the outside of the truck. Also, there is soot before the turbo that houses the veins. Just wondering if the muffler could be partially plugged and causing both problems?
DIESEL PULLER
VIRGINIA,MINNESOTA
The exhaust before muffler is leaking soot , could it be from oil or fuel sitting in the e piping , because of long idling time on maneuvers, before I picked it up and drove it 260 miles. I wonder if the never gets up to temp on short trips. Any ideas.
WillWagner
2,610
Monrovia, Ca.
Well, depends. Is the "leak" a wet looking spray or a solid soot streak? There should be no leaks from the turbo to the outlet of the tail pipe. Got a pic so we can see what you are seeing?
Kohburn
SOMD
looks like a regular old exhaust leak, the one around the turbo housing is the only one i'd be worried about other than it making a mess.
