Sorry another truck wont start
mark_8408
brooksville/florida
Was driving the truck today like every other day, and I parked it and went into the house for afew hours. When I came back out to start the truck, all I got was a click when I turned the key. Didn't even try to start. I checked for loose cables, none that I could find. The batteries are 6 months old, and fully charged. I get power just no start just a click each turn of the key. Solenoid? maybe? Thanks Mark
mojeeper
St Joe Mo
Hey Mark it would be helpful if you told us what truck you have
pardon me I did not see that
1,176
Bad underdash relay or starter solenoid or starter or battery cable or connection.
Warthog
231
OKC, OK
How do you know the batteries are fully charged?
Did you test them with a voltmeter and a load tester? I have seen brand new batteries on the shelf that have had a bad cell.
My first guess is a bad/dirty connection somewhere. The CUCVs are very prone to dirty connections.
K9Vic
Fort Worth, TX
:ditto:
My guess, under dash relay, you can either use "doghead starter relay mod" (search it), or buy a replacement from Autozone. It is the same as the blower motor cutout relay, part #19952. It has an extra pin, this is not a problem and works fine. The doghead relay mod is a better solution, but requires a few modifications to the wiring.
91W350
57
Salina, Kansas
Have a friend you trust 8) hold the key in the start position and tap on the starter from below with a small hammer. You want to hit it just behind the aluminum bell. GM starters are bad about giving you little to no warning that the brushes are shot. Generally tapping will get you a few starts, but she probably is past due for an overhaul. If batteries and all connections are good..... I would prefer to overhaul the stock starter to buying a rebuilt one or even a new one. Glen
Blood_of_Tyrants
10
Lebanon, TN
If you take a screwdriver and short the large battery terminal on the starter to the small start terminal, you will bypass all the start wiring. If it cranks, look for bad solenoid circuitry, if it doesn't then look for bad power connections or a bad starter.
Barrman
1,730
Giddings, Texas
You wrote that you replaced the ends on a "bad" cable. How bad was that cable and why didn't you replace it? Giggle that cable and try to start again.
mark_8408
brooksville/florida
Thanks for all the replies. My problem turned out to be a combo of the starter relay and also the starter. The relay was fried an the starter on its last leg. Going to try one of the ebay starters. Most people on here seem to have good luck, and can't beat 120.00 to the door.
