BTW, if you do this mod, be sure you have the spacer plates that are installed under the front and rear springs on the left hand side. You will probably need longer U-bolts for the left side springs.
These spacers will offset the added weight of the tire and carrier and keep your truck level.
The MWO should be in the manuals section on this site, but if not PM me and I'll get either a hard or electronic copy to you.
It is time for you to buy and READ the manuals. Cover to cover. Look closely at the pictures. Most of 90% of what you want oIt is time for you to buy and READ the manuals. Cover to cover. Look closely at the pictures. Most of 90% of what you want or need to know is in them. Then, when you can not find it, Use the parts manual breakdowns. Then try the internet. (What did the world do before the internet?) 5 seconds on Google and I found the MWO on Portrayal Press for $7. I found it free on another site, but you had to download a third party software. Further searching found it viewable. Stand on your own feet and LEARN about your own truck. Use search functions on multiple forums and find the answers to your questions. It makes your hobby more enjoyable if you can actually figure out things for yourself. And there is no APP for that.
I found the MWO, Rhodesia. Now I'll try to scan it into my files and post a copy.
If I can't post a copy, you may have to send me your direct email because I can't add attachments to the PMs.
