Speedometer question
Thumper580
210
Virginia
For some reason my M998 has a kph ONLY speedometer on it. I bought a replacement one with mph/kph on it. Installed it and it's about 15-20mph off (low). I checked it with the GPS on my phone. The kph speedo is really close, only about 2kph off. The cable had a kink in it so I replaced the speedo cable..... No change.. Is the speedometer I bought a real one or a KMart special? Thanks.
Action
1,556
East Tennessee
CLARK BROTHERS is a legitimate company. Did you compare the 2 speedos to see if the KPH was the same on both at a particular speed? If both the same, then issue is elsewhere. It is free to take apart the parts near the transfer case and clean and inspect. Make sure the little square pin is not rounded.
Thumper580
210
Virginia
The kph one reads good when comparing it to my phone GPS when set on kph. New speedo cable. The new one reads 15-20mph low on kph and mph....
86humv
497
Texas
You got the wrong one...it fits : M35, M54, M809, M939, M38, M37 etc.
You need a : 12338463, nsn6680-01-195-2146
Thumper580
210
Virginia
Bloody hell..... I ordered another one a few hours ago and thank god it's the part number you listed above. Hopefully, it works correctly. Thanks.
