electraman
- 0
- 0
- Charlotte, nc
Can anyone tell what the difference is between a Spicer 3053 and a 3053A tranny? Which one is better?
Thanks!
Thanks!
No not really, the 3053A was a good used take-off. A little bit more of a grind coming into and out of fourth, also it's probably my imagination but first seems a little higher now.Thanks General! Did you notice any difference?
They bolt right in, it's an easy trans to swap. What about the 3052 differences?Thankss General! I am very hew to all this, but I have always wanted one. I climbed up under there today and they look like they bolt right in. Did you replace yourself and if you did, did you run to any problems? I have a 71 AMGR M35A2.
3052 is from the 331 gasser deuces. Has the 4th and 5th spots reversed and no OD.What is a 3052?
...... a number.......?What is a 3052?
