OK, as promised, here are some pics of my spotlight installation.
I used light 'poles' from a bridge truck.
I wanted to be able to direct the lights from inside of the cab, so that determined the area to mount them. The drivers side didn't leave me with a lot of options for mounting the pole, so I attached it to the windshield frame. I could have shortened the pole to windshield frame heigth so it could be dropped with the windshield, but I never put the windshield down so I left the length. I can always change the length if I had to.
I had more to work with on the passenger side as far as a mounting location. As you can see, I attached the pole to the exhaust stack mounting bracket, and added my own bracket to the upper exhaust stack. It worked out well.
The lights themselves have an 'on/off' switch built into them, but I wanted to be able to control the power from in the cab. I made a mounting bracket for under the dash and installed 3 switches. My beacon lights switch was relocated to the bracket, and I installed individual switches for the spotlights. I just leave the spotlight 'on/off' switches in the 'on' position and power them up from in the cab.
I really like them. I can't believe how much light they put out!
Power is drawn from the #10 wire and connected to a 20A circuit breaker, then to the main switches.
Thanks guys for your help with this project!
