sprag case bad
89deuce
st.cloud fl
my truck has a sprag case and is bad it slips except in 1st and reverse. is their anyway to fix this i only use it in the woods and to haul the mud truck out. (ocasional in town driving). is my only option a airshift i read about the reb kit but i called the company that made them and they dont make them anymore can anyone help me.
ASTFU
union ME
the sprag only works in first and reverse? You can do a conversion to air shift ther are plenty of guys on here that have the parts needed.
JDToumanian
14
Phelan, CA
You need the whole case, plus additional parts - the air toggle switch, bracket, pressure switch, wires for the indicator lamp, and some pipe, hose, and plumbing pieces.
To internally convert a sprag case to an air shift case is technically possible, but difficult, and sourcing the required internal parts that are different and the trouble and expense to do this work makes it impractical when there are plenty of complete air shift cases available to swap.
Jon
gringeltaube
Staff Member
2,468
Montevideo/Uruguay
Yes: disassemble the shift rod, clean, inspect, re-lub, re-assemble all components, adjust as indicated in the link above.
See how it is supposed to function and how it may look like inside your tube, here: http://www.steelsoldiers.com/deuce/32130-shifting-sprag-tc-how-works.html
Besides simple mal-adjustment the coil spring may be weakened from rust or even broken in two.
Both your internal sprag clutches themselves are OK, if you have front wheel traction at least in 1st & R.
G.
Bill W
44
Brooks,Ga
I have a sprag tranfer case here in Georgia ( 30205 ) for $100.00. I bought it to put in my deuce but had since found a airshift.
