TURKEY131
- 0
- 0
- Barnegat, NJ
I did a search and could not come up with anything. Does anyone know how to test the starter relay to see if it is bad?
You can eliminate that relay, to test if that is your problem. To do this, you can remove wire# 74 and connect it to wire #214.
That relay does fail occasionally. There are several ways/things to test.
Do you have a digital multi-meter?
Hey Mr. Doghead,You can eliminate that relay, to test if that is your problem. To do this, you can remove wire# 74 and connect it to wire #214.
I hadn't intended to, no. But I suppose there's some interest here that I should see how well it comes apart.Are you going to dissect the old relay?
It might be fun to see the inside.
IIRC, it's not too tough to take the bottom end off. 4 screws/nuts, and it's sealed with a cork-type gasket that you might have to break loose. Once you get inside, you might just find the angled contacts are dirty. With a good cleaning, you may have a functional back-up relay. If you remove the posts, just be careful not to crack the phoenelic insulators (they look like little formica rectangles) be gentle with the post grommets and mindful of the order the post components were assembled. When you reassemble, you can seal it back up with a bit of RTV on the remaining cork mating surfaces.I hadn't intended to, no. But I suppose there's some interest here that I should see how well it comes apart.
Thank you! That'll certainly help, and I wouldn't be against having a workable backup either.IIRC, it's not too tough to take the bottom end off. 4 screws/nuts, and it's sealed with a cork-type gasket that you might have to break loose. Once you get inside, you might just find the angled contacts are dirty. With a good cleaning, you may have a functional back-up relay. If you remove the posts, just be careful not to crack the phoenelic insulators (they look like little formica rectangles) be gentle with the post grommets and mindful of the order the post components were assembled. When you reassemble, you can seal it back up with a bit of RTV on the remaining cork mating surfaces.
Yeah, it is well over-priced for what it is, but I really just wanted an exact replacement. I considered buying another 100A continuous relay from Extreme Outback products like I had done for my Supplemental Electrical Air Compressors. If I need to, perhaps I'll go that route in the future and locate the relay further from the exhaust.Prestolite
WSE-4101A
24V DC
50 Amps
Ord. No: 19207-6183391
NSN: 5945-00-636-8779
MFR: 7E656
Wow, that is one pricey little sucker! It is only a 50A relay. Perhaps it would be a good idea to identify current alternatives for this part. Something like this could be made to fit: At $45 a bit less expensive.
https://www.amazon.com/STARTER-SOLENOID-CRAWLER-DIESEL-3T-3421/dp/B013TCQAAO/ref=sr_1_7?s=automotive&ie=UTF8&qid=1518542500&sr=1-7&keywords=24V+starter+solenoid&dpID=41wGoOlhHiL&preST=_SX300_QL70_&dpSrc=srch
