cosmobius
- 0
- 6
- Tetonia, Idaho
Well, it happened. i was away from home without tools when i started the truck and heard what sounded like the starter still cranking. I turned off the ignition and it was still running! With no one around to borrow tools from and not knowing about the starter relay under the dash, i raced home about 3 miles. I called my wife to have my socket set in the driveway waiting for me. When i got home, the starter had stopped running and the tell tale smell of fried electrical parts was heavy in the air. She was smoked.
I yanked the relay (smoked), and the starter (smoked). The starter's teeth were worn down on the outer edge (toward the flywheel). what would be the cause of this? The starter was a gear reduction starter with no shims and was not attached to a bracket. The two bolts were all that held it in place. Could the teeth have been worn like this due to there being no shims or is it likely that it happened when i drove it home with the starter running?
The truck is an 87 1028 and the TM states that trucks newer than 86 (if i remember right) may not need shims. Is it because they started using the gear reduction starters?
I have ordered a new HEAVY DUTY relay to replace the old one. I tried finding the SME relay Doghead wrote about and had a hard time finding the exact number but the one i bought has a similar rating. hopefully it fits ok. I will provide an update when i have installed it.
