Starter wiring Sanity check
nd1775
Colorado
I'm hoping somebody will tell me I did not miss-wire my starter. I was not able to find this topic in another thread. Please point me in that direction if it exists .
Because I did try to start the vehicle wired as it shows on the photo. Which I thought reflected the TM.
It didn't crank, there was no sounds or fireworks, but I get the sense that I crossed the wiring.
Can I correct the wiring or do I need to purchase a new starter.
WWRD99
1,715
York Pa
Can you hear the starter relay click inside the cab when you tried to start it? Under the dash where the radio would be.
Sent from my SM-S906U using Tapatalk
WWRD99
1,715
York Pa
Little wire should be on s terminal not r.
WWRD99
1,715
York Pa
I thought I had it how the diagram showed
Do you think I damaged the starter?
No I doubt you did any damage to the starter but hook it to the s.
WWRD99
1,715
York Pa
Is that little wire purple? I don't remember the end with that plastic part on them like a fusible link...you sure that wire is the right one for the solenoid? I'd test it in the start position to see if it gets power. Plus you should hear the relay click under the dash.
nd1775
Colorado
I think that little one is red. But it sounds like it should be on the other connection
nd1775
Colorado
Thanks I appreciate it. This is my second try, second starter.
They deleted the rear starter mount and finally got it from John at hillbilly wizard today.
Figures I fouled up the wiring.
I'll go another round tomorrow, try and switch the wiring without dropping the starter.
