Starting problems M-1010
dennisS
Tucson, Arizona
Question: Just finished the doghead modification on the starting relay, both batteries are fully charged, changed the ignition switch, have a new starter and I still can't get it to even turn over. Just the relay clicking on when I turn on the key. Any ideas?
1,807
Is the relay sound from under the dash? If so you will need to trace and check that wire from the relay to the starter solenoid.
NDT
6,342
Camp Wood/LC, TX
Check the thick purple wire from the doghead relay to the starter motor. It goes through the bulkhead connector in the firewall under the brake booster.
m38inmaine
57
Maine USA
As said check the purple wire with white tracer at the starter to see if you are getting power there with the key in the start position, if so the starter is probably bad. I had the purple wire chafe against the vacuum pump and cause all kinds of start problems.
dennisS
Tucson, Arizona
Spent the day working on the problem. Purple wire was fine. We finally jumped to the positive bar with jumper cables from our pick-up and it started up...prior to the jump we were reading 13 v. for each battery (I have converted to 12 v.). I'm now going to replace a couple of the battery cables that might be a little suspect. Apparently I need 14 v. for the starter to kick over. Once we got it started and let it run it started up just fine after that. Any more suggestions knowing this? It was reading 14 v. when the truck was off and on.
Warthog
231
OKC, OK
You really need to tell us upfront that you have converted to 12v. Keeps us from wasting a bunch of time.
13v should be plenty to crank the engine. I would load test you batteries to make sure you don't have a dead cell. Many batteriers have been going bad lately. Also your battery cables may be bad as you suspect.
Fully charged batteries should read ~12.5v with the truck not running and ~14.5v with the engine running
admiralking
Las Vegas, NV
I just bought a M1009 CUCV from govliquidation.com. When it wouldn't start I checked the relay under the dash. Not only do I need to do the modification but the four wires had a meltdown and fused together. I am in the process of separating and repairing wires. Is the red wire supposed to supply 24 volts? I have the wiring diagrams and I've searched the forums (which are terrific) but I can't determine if the relay is supposed to deliver 12 or 24 volts to the starter solenoid a via the purple wire.
ImageUploadedByTapatalk1356239726.977890.jpgImageUploadedByTapatalk1356239784.853727.jpg
m38inmaine
57
Maine USA
The relay is energized with 12v from the ignition circuit and sends 24v to the starter via the purple/white wire.
