Steering knuckle studs replaced with bolts
yolner
68
Rockville, MD
I need to replace a couple of the studs and was wondering if theres any downside to just swapping them all over to grade 8 bolts with lockwashers? I looked around and the folks using the 2.5 ton axles for custom builds do it fairly often, but wanted to check with the great minds here since I don't want to see a front wheel bouncing down the highway.
fsearls92
150
International Falls, MN
Bolts would be hard to get the wheel lined up and stay in place to thread in the bolts. Studs make it easy to use a pry bar to bump the wheel onto the studs then thread on the nuts. Just my thoughts
rustystud
2,815
Woodinville, Washington
Generally speaking, "studs" are stronger than bolts where aligning parts is concerned. If you have nothing else but bolts then use them, but I would really replace them later with quality studs.
yolner
68
Rockville, MD
Cool. Just ordered some new studs. Part number 5MTU2 seems to be almost an exact match to stock. Got them off grainger.
gringeltaube
Staff Member
2,479
Montevideo/Uruguay
Careful: original studs are shorter, on both ends. You certainly don't want them to protrude too far!
Sadly, none of the typical bolts & nuts suppliers have the exact size studs, so you must go with the 2.0in-lenght and trim them down, on both sides.
Edit: I just checked one of those steering knuckles: All 12 bolt holes are about 1" deep; drilled all the way through and fully threaded, in most cases. That means that the coarse-thread end (of the 5MTU1 studs in question) will easily fit, with no modification required.
yolner
68
Rockville, MD
Are you sure the 3/8-16 side needs to be trimmed? Looked at my knuckle and seems like the hole has at least 3/4 of thread depth before it comes out inside the knuckle.
yolner
68
Rockville, MD
Haha.... I just came back from my shop, after checking exactly that!
See my post above, now edited.
So I've been thinking about this more. Would the extra .203" on the 3/8-24 side actually interfere with anything. The hub wont touch them and none of the brake parts should either. Am I missing something?
gringeltaube
Staff Member
2,479
Montevideo/Uruguay
Difference is .23" (almost 1/4 inch longer than stock)
I will have to take a closer look, too. You are right that the hub won't interfere.
I think there is a reason for them studs to be kind of short. But it wouldn't be the first time I'm wrong...
87cr250r
1,982
Rodeo, Ca
Split lock washers have zero locking effect and introduce additional problems.
They can break and fall out leaving the bolt loose.
Water can get to the threads through the split causing corrosion and seized bolts.
They make a burr on the nut that can bite you.
yolner
68
Rockville, MD
Did some measuring and the backing plate, spindle, and shield are about 0.66" thick. The only potential spots where I can see the studs hitting is at the two upper brake adjusters. There's about .875 of space between the bottom of the adjuster and the spindle/dust shield. So if we use the 2" stud my math tells me there's about 0.220" of space left under the adjuster. I think the 2" studs should work without trimming.
