peashooter
- 205
- 63
- Hanover, minnesota
I need some help trying to figure out why my deuce is still so slow at building oil pressure. I changed the oil and added the Spin on filter kit to replace the canister oil filters. the Filters I put on are the Wix 51458 that have the anit drain back valve. Everyone says this should reduce the time taken to build oil pressure to 3 seconds. I have not seen a difference in the time it takes to build oil pressure... its still around 13-14 seconds, at which pressure shown on gauge at idle is right around 15psi at first then goes up slowly. I noticed once after turning it off for about 4 hours and restarting it that it still takes that long. If its been off for under an hour it appears to build pressure pretty quickly (under 5 seconds if memory serves).
Any help would be appreciated.
In case it helps the diagnostic, its a 88 M109a3 with 15,000 miles, Hercules
