Wire Fox
- 161
- 63
- Indianapolis, Indiana
I was putting the linkages together for my NP242 and made the discovery that I apparently can only shift from H to HL and back. If it try to shift it farther into N (and L), it just won't go. I can feel a vague attempt at it moving, but it feels almost like metal flexing at the shift tab and it just won't budge anywhere. As I've learned more, I've come to realize that this is what the "Transfer Case Inop. - NMC" note was all about, and I wrongly (and quite naively) assumed that this was the replacement transfer case, when it really was the broken original.
I've read into the A1 troubleshooting guide and the only thing in the for the transfer case states that if the studs are installed too far in, it can prevent shifting into low gear. In trying to avoid dropping out the transfer case-or at least to make the most of it when I do-does anyone have any other ideas of what may be the problem? When I do take this down, I want to have several directions I can try to go to tackle this issue. As it is right now, the input shaft can be rotated by hand and it will cause both output shafts to rotate as expected. That's at least a vaguely good sign to me that the transfer case is operating in-gear, but just can't seem to change gears appropriately.
