Switch WhaleTail parking brake out
docpadds
Ashville, OH
I see there is a newer style brake handle online right now. I have a whaletail style. Am I over thinking it that switching them out is just unbolt, unhook, do the reverse?
wilfreeman
Richburg, SC
If you change to the newer style, you will have to change the cable also - they are different. I also hear that the newer style catches the seat of your pants when entering/exiting the truck.
wilfreeman
Richburg, SC
Are you talking about the cable gimp? The cable has a grease fitting for the whale tail type, but the lever doesn't. The new style lever is greaseable - I don't know about the cable.
docpadds
Ashville, OH
Sounds like its not worth doing, the whale works its just that i catch the whale one more then the newer one in the other truck.
MikeON
12
Lucinda PA
I have the whale tail brake handle and it is very hair-triggered. The slightest tap when getting in or out of the truck releases the brake. The designer should have put the release on the bottom of the handle instead of the top. I've collected all the components to convert to the new handle except the bracket 16. Does anyone know a source for this, or can provide a few basic dimensions so I can make one? I believe it is part 11647728, NSN 2530-00-033-5252. Thanks.
Wildchild467
56
Milford / Michigan
I think the whale-tail is grease-able and new style isn't also.
Correct. Some of the whale tail parking brake cables had grease fittings. The new style "lock over center" parking brake cables are not greaseable. When I put a new cable in my truck, I sprayed some teflon grease down the cable and worked it back and forth for quite a while. PM is huge with anything.
Wildchild467
56
Milford / Michigan
I have not had a big issue with the handle catching my pants in my deuce. I also have a spring seat for what its worth. Just always be careful and if you are in a sensitive situation where the parking brake is critical, just take your time getting out and be careful. I think any situation where you need a parking brake in a critical situation you want to be careful with everything anyway.
Wildchild467
56
Milford / Michigan
I upgraded my M109A3 to the new style. The whale tale parking break did not apply that much force to the parking brake as the new style. Plus mechanically, I think the new style is more reliable because there are no ratcheting teeth to wear out and you can apply more force on the cable with less effort allowing more users to apply the parking brake easier and with better consistency.
In my M35A2, I have the M35A3 parking brake light on the dash also. It makes it very nice to see visually on the dash when my parking brake is on. Just a nice extra visual aid to be situation aware of the truck I guess.
RAYZER
59
sanford/florida
I have both and like the whale tail better, it feels more positive for hold when you can get that 1 extra click on it.
They both are prone to getting knocked off.
You could also figure a way to put an anti knock off pin in it.
