Thermostat Gasket for the M - 923 1991
borky51
Hartland WI
I'm looking for a little help trying to find the Napa part number for the thermostat gasket I found the seal/thermostat number not the gasket number. I would appreciate the number if someone would have it handy. Thanks
Ford Mechanic
Edenton, NC
NHC 250 or 8.3? I normally call Cummins Atlantic. Some times I'll get lucky if I'm in a bind by going to the local big truck store (Dixie Auto). I don't have luck with NAPA for my big truck parts.
simp5782
Feo, Fuerte y Formal
9,329
Mason, TN
91 is an A2. I have not been able to locate an aftermarket gasket for the spreadsheet. I just did a thermostat on an 8.3 last week and just used ultra black rtv.
Sent from my SM-G860P using Tapatalk
simp5782
9,329
Mason, TN
Oshkosh equip. does have the seal if you are near them.
tbar123
24
enon,oh
Make your own from felt gasket sheets. It's probably much cheaper and you'll have enough left over for a different gasket.
borky51
Hartland WI
Thanks guys I still had no luck finding the gasket at Napa but did take your advise on getting the heavy duty felt gasket sheet for $3.00 and will have enough to make 6 more off that one sheet. The Napa Numbers were wright for the Thermostat 358-180 and the seal 4662 You guys have a wealth of knowledge with out your support and response guys like me would really be in a bind. Thanks again for your help
