Hey,
I have been having issues with being locked out of the brakes completely on my M35A2. April 2009 I bled the brakes and inspected the whole system. It would easily lock up all 10 tires if you wanted and under normal braking it didn't pull to one side. It has a nice straight line under braking. I am not losing any fluid and have not had to add any additional fluid since April 2009.
This is the description of my symptoms:
You push on the brakes and it get stiff. Next time it doesnt's move at all. In this state there are NO brakes. With some pumping brakes come back to normal and may act fine till the next application of the brakes.
The pedal comes back to the floor instantly due to the spring but you can feel that behind the pedal the actual brake pressure hasn't been released back to fully off. It is sluggish returning brake off position.
I have done a bunch of searching around and talking to member online and this is what I have done so far:
Thanks!
- Always drain the air tanks before/during/after trips
- Added methanol based truck airline product to prevent freezing
- lubed air pack using air tool oil via J pipe removal
Thanks!
