This fell off my starter - do I need a new starter?
dace
Arizona
So I have been working on my new to me M998. I am in the process of making all new battery cables and clean off the connector. When removing the power cables from the starter this fell off. Its the clear the stud on the solenoid is roasted. Im assuming I need a new starter.
Coug
4,351
Olympia/WA
At minimum you'd need to take your existing starter in to a competent starter repair shop and get it checked out.
At worst you need a new starter.
Coug
4,351
Olympia/WA
As long as it didn't damage the windings inside the starter motor, you'll probably be okay with a new solenoid rather than complete starter, but that's what a starter rebuild shop will determine. It's almost always worth the money spent getting it fixed right and not having to remove the starter a second (or more) time
87cr250r
1,988
Rodeo, Ca
If you want to go the gear reduction route the 28MT starters can be found new OEM but they'll have a SAE #1 mounting flange. Aftermarket end housings are about $17 and will convert the starter to pad mount for GM engines.
FlameRed
522
Florida
Heck I think this would fit... then again I am not 100% sure... It's a gear reduction starter so much lighter...
Last month I installed a gear reduction starter. Seems ok so far. Some positives, some negatives. This is the one I used: Rareelectrical 24 VOLT GEAR REDUCTION STARTER COMPATIBLE WITH 92-04 AM GENERAL HUMMER HUMVEE 5.7 6.2 6.5 DIESEL 5744719
Here is the good, the bad and the ugly of the gear reduction I installed... https://www.steelsoldiers.com/threads/argh-flexplate-advice-please.213973/post-2506592
I ended up not using any shims.
I did have my original rebuilt for $300 at a local shop. Looks like new. Keeping it as a spare. The shop had a brand new OEM one for $800,
I replaced my flexplate as a few teeth were eaten.
Good luck whatever you decide!
Coug
4,351
Olympia/WA
If it were me I might buy that, but only if a starter rebuild shop told me that repairing mine would be more. If you really don't want to take it to a repair shop, then that's definitely a decent option.
1 year limited warranty is a little piece of mind; definitely better than a cheap chinesium import.
springer1981
1,150
Maine
I'm a fan of OEM rebuilt locally but I'd also by a OEM take off before any rebuilt at a auto parts store. I don't trust them anymore from years of experience.
juanprado
2,916
Metairie/La (N'awlins)
Wilson is a good quality reman specializing in HD.
Napa also sells Wilson.
Problem is that oreilly unit pictured is not oe hmmwv.
Looks like another application maybe cucv?
spankybear
911
WA
It's not OE... that one is a gear reduction "high torque" starter.... and it can also be installed in a CUCV.... It's an option you can install... I like these as they are much lighter than OE.
cucvmule
collector of stuff
1,155
591
Crystal City Mo
Do you plan on fording streams or rivers? What about mud holes?
That will determine how you want to repair starter/solenoid.
There are reasons why the starter is built the way it has been designed. And it may have been to the low bidder but it was still made for the U.S. Military to be used under extreme conditions.
The saying of "buy once cry once" applies here. The last thing I want no matter where I am is to have to make a call to be retrieved. Repair accordingly (y)
juanprado
2,916
Just curious if you have been able to install that unit in a hmmwv as I see the Solenoid is offset and the clearance is super tight.
spankybear
911
WA
I have not installed one in a HMMWV. The gear started is much smaller than the OE HMMWV starter and the solenoid is about half the size. I believe that the layout/clocking of the starters are the same but could be wrong.
I have a gear starter here for a GM diesel that I had when I had a buch of CUCVs... If anyone is in Washington and want to compare let me know. It is used and I do not know if it works... but we could do a side by side and could post pictures. I am too lazy to take the starter out of my HMMWV and see if it fits...
The only other thing I would need to check it the front bracket... This is needed with these starters. Number 9
