Tie rod ends too tight?!
TLangM998
Buford, GA
I installed new tie rod ends and upper ball joints this weekend, and tightened them to the torque specs via the TMs. But the castle nut goes well beyond the cotter pin hole. Is this normal? Did I get the ball joints and tie rod ends with the wrong size joint shafts on them? I attached some pics below. Also, what is this on the rear of my fuel tank? It looks like a really funk fuel line... that's torn. TIA! IMG_6519.jpgIMG_6521.jpgIMG_6522.jpgIMG_6523.jpg
gringeltaube
Staff Member
2,468
Montevideo/Uruguay
:ditto: .... Except where the boot gets squeezed too much, of course.
In that case I have used thin (stainless) sheet-metal to form a cone and use as a shim.
G.
juanprado
2,867
Metairie/La (N'awlins)
I know ball joints and pitman arm/idler arm and center link are different. I don't like how it is exposed past the nut. But in reality, It is not going anywhere and you could always bend the cotter pin ends down to engage the castle nut U shaped. I don't think that comes from over tightening as the joint would stop at the taper but I wonder if the center link for the 12k is thicker? Pure guess on my part, I have not researched.....
TLangM998
Buford, GA
I’ll look into it. Thanks a bunch!
