Do yourself a favor and check the air hose, that connects to the fan clutch, on one of the LMTV the motor pool tightened the 9/16 AN fitting nut and spun the 90 degree angle back ward, which made the air hose contact the face of the cooling fan , slowly wearing the rubber away, The air hose is connected via a AN barb and if you try to remove the hose you'll have a heck of a time as the barb comes lose from the clutch rather than the hose coming lose of the AN barb fitting.
So I made sure the 90 degree angle faces down or even better forward.
Add your own little PMSC trick of the day to this thread, if you feel like it
