Jeepsinker
- 446
- 83
- Dry Creek, Louisiana
As I mentioned in another thread, I adjusted my valves a couple days back and got one wrong, so I went back in and fixed it today. While I was in there I decided to run the engine without the valve covers installed to make sure I had no valve clatter again and check clearances after a short run. While running I noticed that several of the rockers have little or no oil flow coming up and into the top channel, while others have plenty of oil traveling to both sides of the rocker. I did slide the rockers that were suspect up the pivot shaft and checked the oil passages to see if they were plugged and it seems they are clear. I have read that the front head gets less oil than the rear because of the system also supplying the compressor and injector pump, but there are several on both heads that are this way, even with well oiled rockers on either side of them. Do I need to just forget about this, or might I have some kind of sludge blockage in the oil channels that feed the rockers through the pivot shaft? It should be noted that I found no evidence of galling or wear where the rockers ride. It just seems like all the rockers should show some oil flow. Some of them showed absolutely no oil coming out the top into the lube channel.
