Towing from rear
choll
Las Vegas,NV
I have a heavy duty tow dolly, is there any reason that I can’t back my blazer on it and tow the vehicle with the front wheels on ground. I’m lazy and don’t want to disconnect the rear drive shaft.
cucvrus
9,919
Jonestown Pennsylvania
It will not tow the best with most of the weight on the front axle. I think I would get unlazy and tow it forward. How far are you towing it? Is it possible to let it idle if the tow is not that long. Maybe it don't run. But it takes 5 minutes to disconnect the rear drive shaft and wire tie the end up on the frame. Tape the U joint caps and be on your way. I would NOT tow it backwards for many other reasons. Unless you are driving a wrecker that can handle the sway and has warning lights. Good Luck.
