Trans Help with 49 !
catalinacat
Glendora, Calif
Hello friends!! Iam working on a 1949 mb (cj2a) have taken it apart trans and transfer case, etc.. Still pops out of 2nd gear any help on this is greatly appreciated!!!
FireDozer
Fortuna California
Couple things the bushing is worn, along with the main shaft..which if worn pass spec. well allow second gear to rock back and forth, which in turn push the sincro ring to move forward and thus out of gear. End play of the main shaft is another place to look at..along with the sincro dogs and retainer spring. Also the the area where the input and main shaft marry up..If the mating areas are worn pass spec. then all the new bearings in the world won't fix it. I have found that the wear of the bushing and the main shaft, incorrect end play of the main shaft are the main areas to look at...Hope this helps
Robert
Oilleaker1
Crook City SD
I replaced 2nd gear and synchronizer assembly and it still popped out! Ended up needing a stronger poppet ball spring in the shifter assembly. The info. on worn mainshaft and end float is also correct. !! John
