Coal Cracker
- 2
- 16
- Weatherly, Pa.
After reading all the posts and Tm's on Deuce trans oil, I was so confused, and had not really come to any one conclusion on what to use. I did however decide that GL-1 is ancient at best, and there had to be something better.
I've searched the net, and found a couple JP magazine tech articles that state the 3053 uses 80/90, never mentioning a thing about yellow metals, or synchros safe. I embarked on my week long mission, to find the RIGHT oil.
I started calling every drive train supply house that I've dealt with in the past, and most have forwarded me to the 50 WT. synthetic used in otr trucks, now I was confused of course because there are posts saying use 50 Wt. engine oil, alas we're those posts wrong? because I have not been able to find 50 wt. engine oil.
I have a good friend that works for my local NAPA, this isn't you're rinky dink NAPA, they have small engine supplies to heavy truck supplies, and they've allways gotten me out of weird part jams, He let me spend a few hours looking over their lube spec books, and eyeing up their inventory, all of my looking and calling boiled down to what I am confident in saying is the correct replacement for GL-1.
I have to say that the earlier posts stating the use of 50 Wt. Synthetic trans oil
in the 3053 spicer would be correct, of course don't take my word for it, a pic is worth a thousand words.
I have changed both trans and T-case with this oil, and have noted much better shifting, and no leaks or seepage other than normal. Good Luck
