transfer case
reuben
Spencer TN
I have what's supposed to be a dodge transfer case, 2 speed with front axle drive in and out shift. has 2 rear driveshaft flanges. I suppose for a light 6x6 with seperate drive for each axle. It came in a previously modified '50 chevy truck which I remodified for logging some years ago to serve as a log skidder, the axles are perty much done for as I twisted the back pinion shaft off in a hard pull. front one is ok but don't need it, I'm thinking of hauling everything but the good 350 engine and transfer case to the scrap yard. If anyone needs it it's availible, and a posibly usable front axle if it gets spoken for befor it gets hauled off. I'm 90 mi SE of Nashville. I did get some dodge u joints for the driveshaft once so I guess the dodge label is correct.
