taskunitbruiser
- 51
- 28
- Alabama
My transmission doesn't shift well, and after eliminating everything else I can think of I feel the TCM is just garbage. I had the transmission rebuilt, new OEM throttle position sensor, and zero reason to believe the RPM sensor is bad. Aren't the only things not IN the transmission the TPS, rpm sensor, and TCM?
Should I buy a US Shift Quick 2 TCM or get a military replacement TCM? I have the box under the seat so I assume I could just disconnect the batteries and swap out the module inside the box, correct? This seems easier than rewiring things for the Quick 2 TCM and a more stock look (which I prefer), but it seems some TCM pulled from units are untested and sort of a gamble, particularly if without a return policy. Does anyone know how I can test mine?
