mainer
- 0
- 0
- Bridgton Maine
I have had two separate transmission cooler line leaks of late. Both appear to be due to over tightening which caused cracks at the base of the fitting flares. The transmission oil to coolant heat exchanger, while heavy bracketed, does move and as such the entire assembly is subject to stress cracks occurring over time. I elected to replace both lines with high temperature hydraulic lines with SAE swivel fittings. I haven't reinstalled yet and as such will need to fabricate suitable hangers. The replacement hoses cost $185.00. Hope to check this off the worry list.
On another note, thank you for the air compressor/power steering pump bracket support loose bolts tip! Every one still there, every one was loose!
All the best. mainer
