transmission
goliath
East Wenatchee, WA
I just purchased 2 deuces and drove them 180 miles to my home. I dont remember the transmissions being so noisy when I drove one in the service. The noise is almost like a muncie 4 speed rock crusher trans. Are the gears a straight cut gear? If so then this would explain the noise.
Thanks John
wreckerman893
Possum Connoisseur
15,628
2,047
Have you checked the fluid?...I bought a deuce out of SC that had all the fluids removed from it.
I topped off all the other ones but forgot to check the tranny.....when I took it for a test run it sounded like it was grinding gravel. Topped it off and it was good to go.
gringeltaube
Staff Member
2,520
Montevideo/Uruguay
........ drove them 180 miles to my home.
Sure enough you wouldn't make it that far if the transmissions were drained.
But even at correct oil level they(some) can get very noisy after a while, at top speed. Not all of them are as noisy, though.
Nope, all helical gears, except 1st and Rev.
G.
1,131
When they're "right" they're quiet. Much quieter than an M-22. And I'm familiar with M-22's.
I've got a couple that are really noisy in 5th gear-haven't pulled them down yet, but I'll guess it's bearings. One has been like this for 5+ years.
cobra5
194
Stevensville, Montana
goliath
These trucks served with the air national guards communication squadron on the base. Did you drive yours home or trailer? I drove mine 208 mine to Missoula and had to leave it at my work because the transmission started slipping. I parked it and noticed a good leak coming out of the transfer case. I may reservice and finish the 30 miles to the house but that will depend on how bad it leaks when I start it up.
goliath
East Wenatchee, WA
Hi
thats not good. when did you buy your vehicle? Mine were in a lot of 5, bidding was in march around the 23rd. I picked mine up may 22, one of the 5 went to alaska. here is my email address jjtdl@frontier.com, we may have stories or info to share thanks John
cobra5
194
My truck is one of the five that came from the same auction as yours. Mine was in the first row when you came through the gate and was back against the fence with another truck in front of it. I wonder where the other two trucks ended up.
goliath
East Wenatchee, WA
Hi
I bought 2 of them and a gentleman from Alaska bought one. He picked his up tuesday at 8 in the morning tuesday, I picked mine up at 10 tuesday. The free play on the clutch needs adjusting, its a bit to tight. Brake light switch went out on both rigs and was on the second air pack on the passenger side. luckly I had mine home before they went bad. Dot 5 at a buck an ounce is like gold. dont want to loose much of that
Thanks John
greg2560
Yoakum Texas
You sure it is motor oil...My tranny was over full and ran out the front of the tranny when it got warm from driveing,,,,now got clutch chatter when takeing off #$%^&*
