- 9
- 0
- 1
- Columbus Ohio
I am trying to figure out what holds the rear legs of the mount solid to the cab. I see in a tech instruction reference to rear post mounting brackets and a drawing. are those on all deuces? I have the front clamp bracket and the rear U bolts. Are those brackets only for the gun mount or are there other uses such as convoy light posts? I can't believe that only the U bolts, through basically only sheet metal were all that was used to keep that much weight solid enough to last very long.
Does anyone know of a source for the brackets? If you have a set you want to sell I'm your guy.
thanks, Goldy
thanks, Goldy
