MattNC
- 270
- 63
- Raleigh, NC
So today was the day to head to get the turbo 400 transmission swapped on the M998. I have purchased and received a level 3 700r4 from Bowtie with all the accessories and it was in the bed of the humvee and ready to head out.
Yesterday I had finished installing the tach from SECO and also added a 12V step down and fuse box for the 700r4 torque converter lockup to run off of. I verified everything was working as plan and all checks of the multimeter were correct with 24V were it should be and 12V coming out of the step down and fuse box.
After checking all fluids per the PMCS I go to pull out of the driveway and watching my new tach and I see it shift into second but then not into third. Third is acting like neutral. All revs, no forward motion. I pull over, check everything out, continue on my way and same thing but now I am starting to lose even second. I verified it wasn't a transfer case slipping out by turning the engine off and going into L then back to H with everything working correct. First gear is good and strong and reverse was strong as well with brisk acceleration backing up a hill. The shift to second is like shifting into neutral and now I never get to third. I checked the fluids again, and I was slightly high on the transmission fluid so I pulled a quart out to be in the lower portion of the hash marks. No leaks were seen anywhere and no noise.
I can't see how my electrical work did it with the turbo 400 not having a controller. Its drives me crazy but at least I have the new transmission in a crate in the bed. My wife claims I hurt the transmission's feelings and it mutinied on me, but I didn't see that in the TM's anywhere! As an engineer by training its driving me crazy especially given I've been driving it regularly with zero issues. In 1 mile it went from no issues to DOA. Fluid was barely warm as well coming out of the transmission. Well, it will be trailered to its swap destination tomorrow, and I'll keep you posted what we find out.
