Turbo questions Need help with newer 6.5NA motor
Thesaint025
Ft Myers Fl
Ok guys I'm new to SS and I am looking for some help, I have recently purchased a few hmmwv's all have the 6.2 motors I have not taken possession of them yet still waiting! I had the opertunity to pick up a few low mile 2010 6.5 take out's but would realy like to have the Turbo Diesel is this a simple task? Can I simply add a turbo from a 6.5 take off or is there more to it? I can get my hands on the 6.5 TD complete take out, but it is a bit more money and the turbos have all been cut so I would be buying a EBay replacement turbo unit anyways! I can get the exhaust and doghouse if simply adding a turbo to my 6.5 will work, thanks guys for all your imput in advance!
gimpyrobb
dumpsterlandingfromorbit!
27,785
749
Cincy Ohio
The only 6.5 with a turbo that will fit is the center mount turbo. The heads are different than any other 6.5(aside from van motors), so you'd be better off buying a complete driveline.
Action
1,557
East Tennessee
some things that will need done are a body lift, new doghouse, and modifying the tunnel around where the new doghouse will fit.
Retiredwarhorses
4,143
Brentwood, Calif
the short answer is no...an NA block is not drilled for the oil galley for the rear mounted turbo. The casting is there, just not the hole. Let me add, a GM NA motor doesn't even have the casting, the GEP motors do.
i do and have done numerous NA and Turbo conversions here in the shop.
the new GEP NA's are awesome, the turbos even better.
The biggest parts expense beside the drive train is the 4 speed shifter, body harness and drive shafts.
i have the conversion down to approx 5-6k in labor....the remainder of the cost is on the customer to purchase the parts list I have compiled, that parts list price is an addt'l 10-12k. This is going to vary based on what the customer pays to aquire the parts, a lot of it has to be purchased from distributors.
NOTE: Here at RWH we only do factory OEM parts and conversions, so this conversion can be done cheaper if you bubbaize it.
Thesaint025
Ft Myers Fl
Ok, so I appreciate all the feedback, and here is where I stand, I have two motors sitting side by side on pallets #1 is a 2010 6.5NA with 1009 documented miles,
#2 is a 2011 6.5TD with 2950 documented miles, both have complete motor, accessories pulleys 4l80 trans with transfer case, all linkage, all wires cut at hmmwv, start control box and trans controls box, #2 has AC compressor exhaust manifold, and pipes, and doghouse. To accommodate the turbo What one do you pick? I plan on doing the conversion my self, and I'm not afraid of tracking down the other parts, I have the shifter on its way, just trying to get some input On the path to take, and which path will provide a better out come. Forgive me if I seem ignorant but I have spent countless hr's researching and only seem to be getting more confused, I'm just looking for some solid definitive answers! It is obvious to me that I will need a body harness, I'm not sure if that is it for electronics what other hard parts will I need? Will the hood work? Do I need to change the radiator? Drive shafts ect, Any info will be helpful! If anyone has the time to give me a comparison on parts for each it would be appreciated I know a lot of you make a living doing this and I am great full for your experience and input, I'm doing these builds with my son and nephews and we are all excited to get moving, and turning wrenches together and trying to bring back that good old American tradition of greasy elbows and busted knuckles! Thanks Again guys!
gimpyrobb
27,785
749
Cincy Ohio
Unless retiredwarhorses indicates a massive amount of parts swapping to make it work, I'd go turbo motor.
Action
1,557
East Tennessee
What did the 2010 6.5na motor come out of? If it was a 2010 Humvee, it would be a turbo diesel.
both drivetrains prolly have a transfer case with a hole at the back end. Those will require a different driveshaft than you have now, which is prolly a u-joint.
Retiredwarhorses
4,143
Brentwood, Calif
thats an NA, not sure if your other motor is a Turbo or not...but if you have a turbo motor, go with that.
the same amount of work has to be done. I can tell you that both The NA and turbo with the new trans is freakin sweet and drives beautiful. You can't really go wrong with either of them.
Your welcome to call the shop to discuss the conversion.
