cyamaha2007
- 3
- 18
- Warrenton Mo
I want to use a airshift t-case in a homemade tractor. I need a way to lower the drive shafts to the front and rear diffs since it will articulate in the middle. This means i want to re clock the t-case vertically. How does the t-case lubricate. I believe i can make a new fill at the top, block off the original vent and create a new vent at the top. Maybe add a additional resivor at the top to help with cooling. I will be over filling the case. This will be a low speed tractor. I can see foaming being a issue. But i wanted your thoughts.
