Valve lapping
johnray13
Chantilly, Va
I have a 6.5kw 2 cylinder air cooled onan nhd. The manual states not to lap the interference valves (45° seat angle and 44° valve angle)
Is there any harm to lapping them and whats the reason? I noticed older manuals for this same block only suggest avoiding lapping rather than stating flat out not to do it.
John
m-35tom
221
eldersburg maryland
there is simply no reason to lap, nothing to be gained. you can use prussian blue to confirm the fit, that is all you need.
M543A2
11
Warsaw, Indiana
Phil 2968 is correct. Lapping could destroy the interference valve angle. Checking contact with Prussian Blue as M-35tom says will tell you how the fit is.
