- 8,527
- 2,728
- 113
- Monrovia, Ca.
A guy I know has an AM General made A2. He took it out to the desert last weekend and after 3 or so hours of trail riding, it started to hesitate and eventually stopped running. He removed the plug on the bottom of the carb and some chunks came out, re started it, drove a bit and it started doing the same thing. When he removed the inline fuel filter that was installed before the inlet to the carb, fuel shot out of the line, it re started and did the issue again and this time when he removed the plug in the bottom of the carb, nothing, then fuel came out under pressure.
I looked at it after he got it home....it was driven to me, so I don't think it is a carb issue and the oil was not over full or didn't smell of gas. It is an A2 with some of the emission hoses removed, well, the two from the air filter and the 5/16 one coming out of the fire wall to the filter. I have not really worked on one of these, but if the line coming thru the firewall is a vent that goes to the the air filter from the tank and it is plugged, could this cause an issue that seems like vapor locking? Pressure and sucking a vacuum in the tank?
