Vibration/Noise - Bad Transfer Case?
Corvette1974
Upper Black Eddy, PA
Hello,
I just took my deuce to the NYC Veterans Day parade, and had an amazing time! It made the journey no problem, but on the way home, it started to make some sounds/have a vibration. The drive was about 65 miles each way, so everything was well up to temperature.
The truck has a high frequency vibration while moving under load, and more of a gear whine sound now. The transmission shifts flawlessly and the truck moves fine. I do find that when coasting to a stop in neutral (trans) the truck has a sort of shudder/vibration until it comes to a stop. I have not checked any fluids or done any in depth diagnosis yet, but the fluids all have less than 1000 miles on them. While I was driving at speed, I did flip the airshift for 4wd, and it made no difference.
All driveshaft yoke bolts seem tight, all input/output bearings seem tight. The transfer case in neutral is smooth, yet in either low/high the transfer case does have a noticeable degree of “notchiness” when grabbing and twisting the jackshaft (trans in neutral).
Any thoughts on what the problem could be?
-Will
Jericho
69
Landaff NH
I had a loose jack shaft a few weeks ago, noticed the same symptoms driving the 150 miles back from the Weare Rally Tightened it up , but although the vibration seemed to lessen it was still there. Had a little notchiness in one of the Universals so I changes them both. reduced a little ,but still there Comes on around 35 mph and seems to ALMOST go away at around 48 mph, Has the feel of a universal, definitely rotational , can feel it in your butt, can almost count the bearings , If you find the cause please post it, Mine is already put up for winter . Changed all my fluids and added oil emulsiphyer l
Corvette1974
I am definitely going to check all of the driveline bolts. How did you check for notchiness in the u joints? Mine all feel tight/don't get hot but I'd rather be safe than sorry. I do know that I had a loos Rockwell input shaft bearing set and changed those, that took out a lot of the vibrations, but now a new set of vibrations is back!
rustystud
2,806
Woodinville, Washington
Have you checked the jack shaft bolts, they might be loose causing the vibration.
I agree with "fsearls92" here. You actually need to torque them, not just put a wrench on them and assume they are tight. I had several that where "tight" but when I actually torqued them they where way off ! Also how are the 'U' joints ? When was the last time you lubed them ? Lube them now and see if it changes anything. You might have some going out on you.
Jericho
69
Landaff NH
To check u joints with no load on joint turn it back and forth. Look for a shift in alignment along the longitudinal axis. If the shaft is out twist the joint thru its range of motion and look for , feel for stiffness or a notch flat needle bearing feel. As you twist it thru it's range of motion
Jericho
69
Landaff NH
Grasp and turn the unloaded jack shaft , observe the longtudinal axis for misalignment, If the bearings are shot the joint will have looseness in it. Or if its removed, manipulate the joint thru its range of motion, As you wiggle it around you will be able to feel if its stiff or "notchy) meaning one can feel the individual needle bearings as you rotate the joint.
Corvette1974
Also check pinion bearings. Rode in a truck with one bad one and the vibrations were noticeable.
I replaced the front rear axle pinion bearings. They were noticeably loose - all of the rest *seem* tight. Is there any other way to check?
Lubed them all less than 1000 miles ago. Will lube again. I'll throw a torque wrench on them this weekend....
Corvette1974
Then by that metric, the joints are tight. They also do not get even remotely warm after a long drive, I am assuming it would be very hot if failing.
Jericho
69
Landaff NH
if the bearings are going they get hot and the noise generally will alert you prior to failure , The pinion bearings hum, will have to think about it, I regreased every thing, and did the long bar flex check ( prying everything every which way) Bearings are pretty STOUT, hadn't given them much thought, Now you have piqued my interest, supposed to warm up to 30 degrees tomorrow , will have to look !
Corvette1974
I don't spare any expense on grease and lubricants, Good grease is paramount !
Good fluids and grease were used. Less than 1000 miles ago everything was changed (even the steering box oil!)
Is there any other way to check for bad pinion bearings than lateral play? When I changed the front rear axle pinion bearings, it had noticeable (1/8 inch) play. The rear rear axle seems tight and the front axle probably only has 1/16 inch play at most.
-Will
