- 2,186
- 86
- 48
- Zimmerman MN
Hi guys: I'm installing an RT524A and R442, I know radio A (524) has to have the link in the 1029 mount in the direct setting, and radio B(442) normally has the mount 1898 link in the remote setting requiring Radio A to be on to use radio B. My question is can I put the link on the radio B mount to direct so I can use radio B without turning on radio A, or will it make no difference and I'll have to turn radio A on regardless to turn on radio B, the Tm doesn't really indicate? (assuming normal power cables CX-4720 to the radio A mount and CX-4721 from radio A mount to radio B mount.) I'm gonna guess I would need to drop the CX-4721 cable and install a second CX-4720 from the batteries to the radio B mount to use them separately?
Thanks guys if you can shed light on this. Also, I plan on hooking up my VIC-1 system to the Radio A mount via CX-4723. Will the Am1780 have power without radio A being on?
