Warwag - m1028
WARWAG
Well as some of you know I went and picked up my new to me M1028 hence forth to be known as WARWAG. This morning was -8 below and she had a bit of a time starting but start she did. I drove her around and noticed she was having a hard time shifting. Actually she wasnt shifting. Figuring it was the cold fluid I drove her for a bit and then accelerated. She shifted but at a pretty high RPM which I didnt run at before. Then she shifted again into third at a pretty high rpm as well. I took her for a spin up the road. She drives fine. mechanically she seems fine. I believe the shifting issue just may be what they all are? Not sure but the shifts were firm and instant. Feels like a shift kit to me. Is this the norm for the M1028? I also cleaned up the windshield and got the grease pen crud off. I used my wifes nail polish remover and it did pretty well with some elbow grease. Behind the seat I found a fire extinguisher and a deconaminating spray bottle. Pretty cool looking. Also a box of reflectors. Also in the cab is an original vehicle maintenance binder with another set of keys. One for the ignition and one for the anti theft steering wheel lock (read chain and lock). Unfortunately the problem is its not the one to this truck! Says 18,549 miles at turn in. Diving a bit deeper that vehicle has 118,549. Plus the Vin# is wrong. So to my other SS brothers out there headed to Nellis to pick up your rig check the Maintenance log and see if its the one for your truck (or mine). There are also two rifle mounts in the vehicle. One on each side of the seat. The body on mine is not as nice as I had thought. The roof of the cab has a BIG crease down the middle. There are also various dents and scraps not seen in the original GL photos. OH well I think I will make this into my plow truck or Off road truck. She will be road legal and registered. Overall she is a good running vehicle. Here are some pics from todays run. Oh and there are absolutely NO leaks anywhere!
WARWAG
Some pics
91W350
57
Salina, Kansas
I doubt it is a shift kit. I am betting it is a solid turbo 400 hitting a 4.56 ring and pinion. They are firm, sometimes you almost feel sorry for the u-joints. You will learn to just ease off the throttle like you were getting ready to do a manual shift. When they are really cold, they do seem to hold out longer until armed up. I am on my second M1008 and I love the truck. Glen
1,808
If the shift is high even at a part throttle response, I'd check vacuum lines if the 400 even uses them.
rnd-motorsports
Evart,Michigan
congrats Looks like you got a good truck I would bet with the yellow stipes on oil pan you have a newer engine in it at least . Mine shifts at a higher rpm when cold and on high idle but once the fast idle kicks down at 110 deg by the gauge it shifts sooner check vac lines and injoy the truck looks great! I agree! With the locker in rear and posi in the front they are the best plow trucks!!!
67_C-30
Sweet Home Alabama!
I agree with this. My M1009 shifted hard and held the gears a little too long when got it from GL, and it was it a vacuum related problem. I replaced all the lines from the vac pump to the vac switch on the IP and to the transmission and it made it shift normally.
87cr250r
1,988
Rodeo, Ca
Your shifting is most likely an issue with the vacuum regualtor system attached to the side of the injection pump. Mine also has a similar issue. The rubber boot on mine is rotted and likely leaking which makes the transmission think the engine is at full throttle which is why you get the late, hard shifts.
azM35a2
Phoenix, AZ
perhaps best to just have a local locksmith rekey everything for you. here in phoenix i know theres places that'll rekey the set for $80
