ke5eua
- 41
- 48
- Baton Rouge (Central), LA
Ok so I pull off to the service road because I was getting the check engine and gauges lights and buzzer.
Shut truck down and started going over it to make sure everything was ok.
Get back in and it won't start. Turn the switch and both battery gauges so in the yellow as normal but when you go to start nothing. Relays click gauges go off but nothing.
Thought it might be a battery issue again so I took the two batteries out of the 818 and put them in the het, same thing.
Any advice, help?
Current located in seguin tx off i10 east.
Any advice, help?
