Water Fuel Separation
Amxhunter
Mobile, Alabama
Just given 2 55 gallon drums of waste oil. However , I suspect they have a significant amount of water in them.
Any thoughts on this ? Could always use it to control the crab grass :wink:
Any simple way to separate the water out ?
TIA
Uglyranger
Waverly Hall, Georgia
Tip the drums at an angle for several days, then stick a siphon hose all the way to the very bottom, drain the water until you start getting oil out of the hose.
Amxhunter
Mobile, Alabama
Kind of already tried that.
I have a bottom feeder barrel pump. Drum has been sitting for about a week. Pumped out about a gallon today and got what looked like really thin oil. My concern is that the oil is actually hyd fluid and may be hydroscopic.
If that's the case , am I screwed ????
I pumped out about a quart 3 days ago and put it in a glass jar. I shook it very hard and did not notice any real foaming as I usually see with a water component.
However, today I added several ounces of water to that same jar and shook it again. No foaming this time either.
WillWagner
2,635
Monrovia, Ca.
Let it sit for a few weeks. Draw off the top until you see a difference in the material you are pumping out. The H2O will hang at the bottom and you'll see it when it starts comming out.
