What do you have your air pressure set at?
RaggedyMan
Lynchburg Va
I have been researching air pressure threads for various reasons and have noticed wide differences in pressures people have their govenor set at, anywhere between 80-120 psi. Is it personal preference or is that just the way you bought it and never had any reason to change it or like me, replaced the govenor and that's what it was set at?
Mine is at 100 psi. Is that good, bad or does it really matter?
VPed
307
Clint, TX
My deuce has liked 90 since I got it and the other three trucks I've had were at 110-120. No problems with any, performance-wise.
frank8003
4,985
Ft. Lauderdale, Florida
A comment for consideration.
Install a known good calibrated gauge off ofIMG_6454.jpg the in-cab
under-dash port
Before you go messing with things.
The in-the-dash air pressure gauge is about
as accurate as the fuel gauge.
rustystud
3,124
Woodinville, Washington
Federal standards say an air operated brake system should have a compressor that builds air pressure up to 120 PSI. All over the road trucks and busses have their air system set to shutoff at 120 PSI.
orren
26
Live Oak, Florida, USA
I have an air assist steering system and the higher pressure makes thing better.
RaggedyMan
Lynchburg Va
120 psi sounds good to me (I always say more is better) but in the case of a 50 year old truck I worry that more pressure is bad(?) on the hoses.
brianp454
11
Portland, OR
ALL of the gages in the truck are a "suggestion." I recently tried a pile of gages for air pressure and got readings all over the map. I would like to check with a bonna-fide, calibrated, high quality gage and toss the ones with innacurate readings. I would prefer not to buy another tool! Any idea on renting or borrowing a gage local to me?
rustystud
3,124
If your hoses cannot handle 120psi then they should be replaced anyway. My home shop air-compressor makes 170psi . Standard home shop compressors from Home Depot make 150psi .
m16ty
218
Dickson,TN
You can never have too many tools. A decent gauge can be had for less than $20, I believe I'd just pick one up if I were concerned about it. With a proper fitting you could even use a tire air gauge. You should have one of these anyway if you own a MV (or any vehicle for that matter).
As has already been stated, 120psi is the correct max pressure.
