what does this fit?
Jones
Sacramento, California
There's a drwg in the tech library of a Hayes wheel designed for the HEMTTs. (Titled wrong; 1100X20 should be 1000X20) Take a look at it and see if thet's the lug spacing on your wheels. If not HEMTT, maybe FMTV or LMTV.
dma251
15
Arlington, Washington
That's a hemtt A2 bolt-together wheel. I sure wish I had just ONE more....... I have 8 now, but I am still searching for a ninth for my spare.....
It's definitely a hemtt wheel, though. I'm tripping over 'em in my garage right now.
houdel
9
36
Chase, MI
vinny-socom1 said:
my friend has 24 for sale!!!! He also has about 16 5 ton trucks that they won't fit... Vinny
Will they fit a 10 ton truck? Pilot hole 11" or so, bolt pattern 10 lug nuts on about 12.75" diameter IIRC? If so, I could use about 9 myself. If those numbers are close, I can go back to the manuals and come up with the actual numbers. That would make them PLS rims, not Hemtt.
Poccur
134
Roanoke, VA
A search on that NSN gives a number of vendors. Oshkosh is one but also Accuride. It lists Accuride part number 29729.
Accuride list is as an active part number, lifted the attached from their catalog.
Have not linked it to a vehicle but it does give more info on the item.
Cheers
Poccur :)
M1075
Oklahoma City
Those wheels might be the 2 piece rims from the M1076. I could use them. Can you PM me with your friend's contact info?
M1075
Oklahoma City
screaminseeman said:
I have a couple sets of these wheels, one of witch I will be running on my bobbed duece. Does anyone have a good inexspensive source for o-rings for these wheels?
Which o-rings are you after? The rims in this thread are not going to fit a deuce without new centers cut. Do you have these exact rims or something else?
